pistons
K
kizzyturbo4x4
will all sr20det specd pistons do the job?
is the rods for R/200sx spec the same regarding piston pin?
just the crank bearing thats not the same?
What was the final decision on rods? sr20det spec, do they all work?
( if only with right bearings)
K
kizzyturbo4x4
sure but thats to simple sad.
and by the way that page still say clutches dont fit. they do :wink:
cmng
clutch will fit
OEM flywheel will not fit
but a lot aftermarket flywheel will fit
i manage to found out that all RWD aftermarket flywheel i have is
bored to 11mm flywheel bolt
Certain clutch Kit like OS giken will not fit
certain kit will fit
i sure OS Giken Twin plate model that have spring on the disc will not fit
( it not listed for GTiR as well )
it hitting the gearbox since it is taller
but those RWD SR like OS single will fit on RNN14
8)
K
kizzyturbo4x4
i know that and thats not what i need to know. the subject is on pistons and rods mate ;) i got a s14 rwd clutch fittet allready. and the flywheel difference is them dim of the bolts that holds it to the crank.
got a couple 200sx and gti-r flywheels..
