pipes?
T
tonygtir
on the bulkhead you have a fuel feed , return , and feed to the charcoal canister correct? im just wondering which is which with them need help asap there is a small canister wit 3 vacum pipes that is at the back of the intake manifold were do them 3 go to ?
I started composing a reply to this but my PC crashed...
Can you explain what you mean a little better; are you asking where the pipes on the charcoal canister go, or the vacuum box on the underside of the intake manifold?
If I remember correctly, the carbon canister draws the air from the fuel tank breather through a little valve on the top; it's opened by the smaller vacuum hose so that the bigger one can then pull the scavenged air into the inlet manifold.
