As above.
First off, neither of the windows worked, so I bought a drivers switch, worked ok.
Then, the new switch packed up, so I bought another one from Bob (which was off a Primera), which I fitted today.
The drivers window works ok, as does the central locking, but the passenger window doesnt work, from either switch.
The motor does work if you short the switch pins out, so its defo either the passenger switch, or the drivers.
There is 12volts at the switch, and an earth.
Does anyone know how the drivers switch controls the passenger switch, especially how the button with the 'x' (which locks the passenger switch) works, ie what voltages should be presnt when the switch operates, as it doesnt seem to change anything at the passenger switch.
It seems a little unlikely that the passenger switch has suddenly packed up as well.
A wiring diagram would be very helpfull!
Cheers, Dave.
Cheers, Dave.
