Part's and where from?
jiw
Hi, im in need of the following parts, my local motor factor's seem useless and its taking my dealer's forever to even just to get a price, i need the following part's:
Rear discs
Rear pads
2 front lower arm's----balljoints and bushes are worn
2 steering rack boots
2 track rod ends
oil filter
fuel filter
clutch release bearing
powersteering belt
alternator belt (not a/c)
exhaust gasket's, both sides of downpipe
big end shell's----standard size
exhaust manifold gasket
set of engine mount's
also i dont mind buying uprated parts if available and as long as the price aint through the roof, help appreciated, jeff :lol:
jiw
Thank's mate, i think nissan are having problem's with the import parts system from what i can gather, they have been for the past couple of day's.
any other reccomendation's, need to get the car sorted a.s.a.p, jeff
Mart
You could check, but i think all the parts ur after don't need to for the pulsar, UK sunny ones are fine
Is that what u ment?
Websnowbo
All my local motor factor's can supply those parts so i should think that any decent ish supplier should be able to get them for you.
I used to work at a motor factors for a whil and bought all my parts from there including a clutch which was a standard AP for 50 quid.
Rear discs ---- Nissan/motor factors or uprated
Rear pads ----Nissan/motor factors or uprated
2 front lower arm's----balljoints and bushes are worn ---- Nissan, maybe motorfactors
2 steering rack boots ---- Nissan and motor factors
2 track rod ends ----Nissan/ bumpsteerkit /possibly motor factors
oil filter ---- Nissan/Halfords/motor factors
fuel filter ----Nissan/ halfords? / motor factors?
clutch release bearing ----Nissan or part of uprated clutch kit?
powersteering belt ----Nissan/Halfords/motor factors
alternator belt (not a/c) ----Nissan/Halfords/motorfactors
exhaust gasket's, both sides of downpipe ----Nissan, maybe motorfactors if you take the old ones to compare
big end shell's----standard size ----Nissan
exhaust manifold gasket ----Nissan
set of engine mount's -----Nissan/Nismo/other uprated?
That's where I reckon you should be able to get them
GTiRich
Nissan been having probs with the import system for about a week now :evil: very annoying. They also wont quote without a chassis number which can get even more annoying when you leave it at home :!:
Call Alan at U-Save 0845 658977 tell him Maria sent you.
