Oxygensensor values to high
Rage
Hi
Have just got my new R from Japan now, and I have problems with the O2 values are to high, so I cant register my car, until the values are normal. (Stupid EU rules!)
Went down from 2+++ to 1.21 by changing the exhaust.
They should be 1.0, but they are 1.21
Anyone got any idea?
Andreas
AJ4
check your lambda sensor ( the sensor in the turbo downpipe ). The emmisions should be exactly 1.0 if this is working ok.
Rage
Okey.
As I understood, the lambdasensor that the R uses, are a special one? That can measure up to 1.6v?
AJ4
Its a strange one... I had one that was 1.2 volts, and the replacement one I got from Nissan was a 1.0 volt one, and I've heard of people that have 1.4 volt one !
Not really sure that anyone knows which one it should be ! :D
Rage
This is great.. hehe. Can I get normal lambda values with a lambda that measures up to 1.0v?
AJ4
strangely enough... yes. Although the Nissan lambda sensors are all different voltage, I believe they are all still calibrated so that the stoich point has the same voltage.. not sure how true that is, but it makes sense...
Rage
Hehe. Weird.
A friend of mine is out on a trip to Nissan now, hopefully they have it in stock... Will post results later.
Rage
We changed the lambda, and. Voila! Problem solved, and my car would be on the road any day now.
I have only driven like 3 or 4 miles in it, so Im really looking forward to drive it this summer!
:D
