antgtir
When the engine is cold (i think) i seem to experience a small amount of overboost, the car is not exceeding the capabilitites of the fuel pump (standard) however there is a noticeable difference in power, acceleration and gauged (standard gauge) boost levels. Once warm the problem seems to be gone.
What could be the root cause of this annomoly?? I have checked all the intercooler (standard) pipes and the small vacuum pipes that attach themselves on to the intercooler and they are all attached correctly and are tight. With this in mind does that point the finger towards a sticky actuator??
If so are there any methods of removing this problem, maintenence and or replacement??
If not, what else is there to check??
Your help in this annoying little fecker will be much appreciated.
Many thanks in advance,
Ant. :?
Ant. :?
