Murff93GTiR
so ive been a member on here for about 8 months now and ive never dropped a post to say hi to everyone....so hi.
now thats out the way im in turmoil in what to do with my R,i got it lat last year after swapping my evo1 for it and loved it ever since.when i returned from tour of afghan with the army i couldnt wait to drive it again and with a bit of extra money i thought i would make it stand out a bit more so got it re-sprayed Bayside Blue,looking great and wanting to show off my freshly painted R i stardted heading home from my barracks in edinburgh when my R desided to splutter,throw out alot of smoke and the die.trying everything at the side of the road to get her started but no luck so a nice recovery home and further inspection revealled that the injectors wouldnt open,tracing it back to the hks fcon ecu fault i replaced it with a stock ecu and loom to then find plenty of fuel....no spark.so pissed off with it i decided REBUILD.upon stripping the engine i found the bottom end was just starting to go so considered this a very luck catch.
so this all happened back in feb and having spent nearly all my tour bonus on parts im finally able to start rebuilding my engine but heres the dilema....im getting a bit scunnered with it and contemplating selling everything and buying a ready done R but dont want too loose the fun of doing it myself.spec so far is:
HI-SPEC 300MM FRONT BRAKE KIT
TEIN COILOVERS
COMPOMOTIVE MO6 ALLOYS
ENGINE BLOCKED BORED OUT TO 87MM FITTED WITH WISECO PISTONS BRAND NEW STD RODS ARP ROD BOLTS ACL MAIN AND ROD BEARINGS
MINT STD CRANK MICROPOLISHED
ALLOY FLYWHEEL
RECONDITIONED CYLINDER HEAD INCLUDING NEW EXHAUST GUIDES AND VALVE STEM SEALS DECOKED HEAD AND VALVES,CHEMICAL CLEAN,RE-SHIMMED VALVES GROUND IN AND SKIMMED,
CLEARANCES SET WITH HKS 264 CAMS AND HKS VERNIERS(O MILES)
FORGE FMIC WITH HARDPIPE KIT
S/S TOP MOUNT TUBULAR EX MANIFOLD
MONGOOSE SYSTEM
ANTI-DIVE BUSHES(NO WISHBONES)
BRAND NEW POLYPUSHED FRONT DROP LINKS
BRAND NEW T/R/ENDS
WHITELINE ANTI ROLL BAR D BUSHES
ZYTEC ECU AND FULL AEROSPEC LOOM WITH COILPACK CONVERSION EX TOURING CAR SYSTEM
COMETIC 1.2MM STEEL HEADGASKET
HEAD GASKET KIT
RECONDITIONED OIL PUMP FITTED WITH NEW CRANK OIL SEAL(LOOKS LIKE BRAND NEW)
theres probably parts ive forgotten but i just dont know what to do.any suggestions guys?
TEIN COILOVERS
ALLOY FLYWHEEL
MONGOOSE SYSTEM
BRAND NEW T/R/ENDS
HEAD GASKET KIT
