PaddyPower
Have the following faults
12 Air flow meter circuit
43 Throtle sensor circuit
All wiring is correct cut and soldered corectly. But the avcr is showing 15% throtle when it should be arround 100? Very strange. Car goes into limp mode and there i am stranded on a busy road.
How do i go about rectifying the problem. Somebody told me that after turning up the boost i should have the ecu reset as it would not accept the changes untill this is done?
a) Am i right in finking a standard ecu can run 1 bar with no probs?
b) how do you reset the ecu? Will this do anything?
AHHHHHH
AHHHHHH
