omex engine management new for 2005
daz
omex professional engine management system.
the omem600 engine management system is a high performance, easy to install, easy to map ecu system designed specifically for the top clubman competitor and low volume manufacturer. The omem600 offers three dimensional mapping, has user adjustable correction tables and is programmable with the engine stationary or in real time whilst the engine is running. The omem600 is suitable for both normally aspirated and forced induction engines.
semi sequential injection for up to 4 cylinder engines
grouped injection for up to 8 cylinders.
distributorless ignition for up to 4 cylinders
distributor ignition for up to 8 cylinders
programmable load and speed sites
tps or map or both can be used for load sensing
wide range of crank trigger patterns are suitable (user programmable)
turbo wastegate control
turbo anti lag system
variable cam control
traction control
narrow and wide band lambda feedback support
stepper motor, push/pull and single line idle controls in addition to scattered spark control
knock sensing capability
3 programmable outputs switched on user controlled inputs (eg boost coolant temp etc)
security protected calibrations
full throttle gearchange
intercooler water spray control
water injection control
nitrous ignition retard and fuel enrichment ]
two cooling fan controls
barometric compensation with external sensor
uses the latest version of the superb map2000 windows programming software
inbuilt independent fuel and ignition rev limiters (soft and hard cut)
separate tachometer shift light and fuel pump outputs
magnetic or hall effect crank and cam sensors
automatic interpolation between mapped sites
sophisticated acceleration fuelling setup
maximum recommended engine speed 12,500 rpm :shock: :shock:
and loads more
D
DOT2DOT
Cheap as chips!!! I presume thats for the basic ecu, for which i will need various other bits and a loom?
daz
loom is obviously made up to fit your car normally made up from the connector on the oem ecu then just plugged in but yes seems a very good ecu and cheap too specially designed for 4 cylinder engines. and obviously if your going to run a map sensor then all you need is a three bar map sensor which are about 30 odd quid.
D
DOT2DOT
Who can map this then? Should any good tuner be able to do it, or would it need to be done by somebody with omex experience?
daz
any tuner should be able to do it but a tuner with omex experiance is always a bonus mate
N
Norfy
got any prices for this management with everything i would need?
just been qouted £2200 for the 600system drive in/out, and its a bit much really.
