Oil Temperature gauge not working
R
Riggsbie
Hello all.....
Just a quickie, my oil temperature gauge does not work :(
Currently I do not know whether the gauge itself has broken or the temperature sender, what is the best way to test the gauge ?
Where does the temperature sender live ? Are they easy to change if this is broken ?
Thanks......
Check the wire hasnt come off the sender first, thats what happened on mine :wink:
The sender is on the oil filter housing.
LOU ROB
No it isn't, the one on the filter housing is the oil pressure sender :wink:
He want's to know where the oil temp sensor is :roll:
Don't you welsh use your k n o b s to take sheep rectum temps :shock: :lol: :lol: .
rob
The oil pressure sender comes off the side of the filter housing and the temp sensor for the gauge is in the top of it :roll:
Next time you're at DP motorsport ask if you can have a look at an engine, you might learn something :wink:
:mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen:
LOU ROB
At least now you've stated which one is the one he's looking for so he'll get the right sensor :wink: :p
Theres only 1 wire on the temp sensor and 2 wires and a connnector on the pressure sensor and i did say "the wire" :wink:
But i should have explained it better, so........ :oops: :oops:
jiw
anybody know what thread the sender is as i might need to order an adaptor for an aftermarkewt gauge, jeff :wink:
GAZ P
My oil temp & pressure gauge don't always register straight away due to the needles sticking, I just flick the gauge and hey presto... :lol:
