oil temp
nismo-400R
hi all,got abit of a problem,i changed my oil temp sensor(stock one) as it had broke now after i changed it and ran it my fan came on when the gauge showed second notch,before it broke the fan came on when it showed first notch,its not leaking water or oil or anything,is it somethin to be worried about?ive also got a front mount oil cooler,thanks in advance
The oil temp sensor measures oil temperature, the radiator fan is activated when the water temperature reaches a certain level (93 degrees C iirc). They're not directly related.
Does you're oil temp actually register as warmer, than it did with the old sensor fitted ?
If it does, I'd suspect the calibration of the sensors, or lack of it is the cause.
I wouldn't worry about but, just keep an eye on it regardless.
Paul
