Oil return pipe nut size needed asap
E
Edd
On the ouil return pipe bolted to the block that the oil from the turbo flwos back into the sump there is a nut to undo it
it is bigger than 19mm but does anyone know what size it is as i ened to get a deep socket to get it off
need to know answer today please :roll: :cry:
B
Brett G
I only done this a few weeks back but really cant remember the size mate, I thought it was 19mm but obviously not :?
Can't you measure it?
Brett
E
Edd
i couldve measured it but i'm not at home :lol: :lol: :lol:
and i want to go to halfrauds after work and buy the necessary spanner :cry:
it's def not 19mm though
i think its probably 22 or 23mm :twisted:
It will be 22mm I'm sure as that's the only other big size used on the R.
rob
memski
11/16 th :wink: Mind you don't force it too much edd lol :oops: And it's a feed not a return.
He's not on about that one memski you numpty :lol:
And you should use 17mm on the oil feed banjo not 11/16 :wink:
Or are you one of these people that refuses to go metric :lol: :lol: :lol:
Where he come's from they don't use spanner's, they just hit it with the butt of the gun :shock: :lol: :wink:
rob
memski
LOL had so many probs with my feed that I instantly assumed it was that for edd :oops: :oops: :oops:
Rob: feck off :p :lol:
E
Edd
yeh mehmet you TW*T
it was the return i wanted off :roll:
in the end i didn't take it off as i would have just got more sh*t in there and the engines f*cked anyway :shock: [/b]
