catchmeifyoucan01
hi i removed the whole sump pan to re-seal it! but i still have a leak it apears to be coming from the top of the oil pump! i cleaned it all off and drove her for 30 miles on standard boost! re checked! all okay no oil leaks! but my standard oil pressure gauge has allways been showing high oil pressure 8 bar when cold and 5 bar when hot! and if i turn the boost up to 1 bar! i start to get a oil leak from the oil pump area and the oil filter! which is a nissan filter! but these only leak when the boost is turned up to 1 bar!! any ideas???
