pulsar kid
Iam stripping my block down ready for honeing,
and was woundering how do i remove the dip stick pipe??
is a hammer and screwdriver the only thing yorkshire men have in their toolbox?
if you get a set of molegrips on the flat part of the tube down at the block, then you should be able just to twist it out
No get a rubber mallet and abit of wood then just knock it offlol ill try that 1st. also do i need a pully removal tool to take the crank pully off as this and the crank and oil pump is the last things to remove before i can get it honed,
Ask Boby, he managed to do it whilst out on track!! Talk about skill!
and put the freshness back:while doing the shake and vac......
