Oil Coolers
T
TomWhite
If your running say a 300bhp pulsar and you run it hard every now and again would you recommend a uprated oil cooler like the nd designs top mounted?
If you do a lot of hard driveing then yes I would, :wink: I think it's a must have item if you plan on doing any track days :wink: .
I have mine front mounted so it's allways in the cooler air unlike on top of the engine.
rob
ashills
no need atall unless u do a fair amount on the track the standard cooler is very efficent if its all clean etc
C
carpy100
dont use a top mount cooler!
think about it mate, the heat soak thing.
put it at the front out the way, give it a flush through first and all will be 8) .
