Green Dwarf
Hi, Have read forums about oil coolers. Thanks Odin 4 idea re remote filter. Will do that. Want to run car about 570 brake, and possibly track it. So what is the largest front mounted oilcooler (as in mounted on the front chassis member) I can get away with, but yet still maintain a healthy oil pressure throughout. - Suffering no engine damage?
Obviously the bigger the cooler, and longer the hose run the greater the pressure loss.
Will I need an uprated oil pump?I assume mine to be standard. Currently have top of engine mounted Mocal 16 row oil cooler which is leaking and does not cut the mustard. It runs 110 celcius and car now is only running 370 brake at best. So I belive when I up it to 570, I am going to need a damn sight bigger oil cooler. what is the best way to go?
If significant are there very low pressure loss oil coolers availble?
Second question: Oil thermostat
I intend to get a thermostat. which is best, in line pipe, or in sanwich plate?
Third question: Oil Capacity
Best way to increase oil capacity without pressure loss?
Cant find an enlarged sump that will fit as per forums here. What about an in line resiviour. A bit like a very large oil filter. Or some other means of getting another litre or two of oil in there? After all, the SR20Det's were designed to run228bhp or so. on 3.7 litres of oil. I am looking for 570bhp. What is the best way of maximising oil capacity and cooling, without pressure loss? Advice gratefully sought!
Regards Mike
Regards Mike
