antgtir
Ok here goes.
I still have the AC and TMIC so upon inspection of the engine bay it is looking extremely tight to fit an oil cooler, plus to fit it into a space which recieves constant direct incoming airflow. Therefore i have been looking around the car for space and a reasonable airflow.
With the removal of the standard exhaust system and the resinstatment of a mongoose there is a large area at the rear of the vehicle otherwise known as the parachute area lol :lol:
Has anyone hung the oil cooler in this area? If so have you had any problems with puncturing of the radiator unit? What length of oil feed and return lines did you get and are they available in this length?
Any other suggestions will be much appreciated.
Cheers,
Ant.
Cheers,
Ant.
