rossdj1983
whilst im on the cooling issue tonight im wondering is it worth putting a small spar fan on my 16 row top mount oil cooler? had to put it up there cause i ran out of space:doh: anyone done it before?
rossdj1983 said:4" fmic + 2" custom made rad +3071 with 4" inlet on = f all space
I'd say its pointless really.rossdj1983 said:ok ok, i couldnt be ased to get longer pipes, but has anyone done this or is it pointless
cmng- start your own thread, answer- yes
But you're not trying to do the same thing with the oil !RishiGTiR said:Why did you move the intercooler to the front? Thats right because the hot engine was heating it up. Same thing will happen to the Oil cooler. Rishi
youngsyp said:But you're not trying to do the same thing with the oil !
dunno yet mate hasnt been fired up since the rebuild, ill let you know soon as mateyyoungsyp said:Out of interest rossdj1983, what peak oil temperature have you seen with the oil cooler in it's current location and, what does the temperature usually sit at on average ?
Yes, you are trying to cool it but, not to the same degree (pardon the pun) as you are the intake charge ! And I didn't say that you did that you did say you were trying to cool it below 70-80 deg.....RishiGTiR said:Yes you are... You are trying to cool it... :der:
I never said you were trying to cool it below 70 - 80deg... But you are looking for efficient cooling.
If the oil cooler itself is sitting at 90deg+ then its not going to do a great job of cooling the oil especially as its being heated up by the engine...
Front Mount, thermostatically controlled cooler is the way to go.. That way once its down to 70 - 80deg the oil cooler isn't used so won't cool the oil below adequate operating temps.
Rishi
only if your engines is made out of lego:doh: :der: .EVOBAD said:thats ok i dont see the point of having oilcooler if your no running good power i only used 1 when i ran my 410bhp ,not sure if ther any good as i had a forged bottom end & still killed my rod ,as we all no u need alot of luck when running big power gtirs & bottom ends tend to go what ever parts are used
youngsyp said:Yes, you are trying to cool it but, not to the same degree (pardon the pun) as you are the intake charge ! And I didn't say that you did that you did say you were trying to cool it below 70-80 deg.....
I'm not debating that front mounting the cooler wouldn't be the perfect positioning, operationally wise but, there is nothing wrong with having it mounted vertically (or as close to as you can), where the TMIC used to be. If it's thermostatically controlled and getting a good proportion of the cool air coming through the intercooler intake, it'll still perform it's job very well and keep the oil temps below 100 degrees.
I've only ever seen 110 degrees max on my oil temp gauge and that was in the height of summer in 2004, constantly using all the rev range etc...
Point is, if you're using decent oil, changing it regularly and have a cooling system that is in good condition, a top mounted oil cooler will be more than man enough to keep a lid on oil temps, no matter what the conditions !
