oil catch tank
hi all just got a catch tank can some body please tell me how to fit it as im a bit lost on the pipe work the tank has one inlet and one outlet thanks pauluk :?
Shaun
:D Hi Paul,remove the standard catchtank,and connect the pipe from the sump to one side of the new catchtank,and the top pipe that goes to the top of the camcover to the other side :D
Do you mean catch tank or breather? We don't have a catch tank as standard, just the separator in the breather system which should drain back to the sump.
At a guess, the pipe that goes to the inlet system would now go to the catch tank and it would collect anything. Not sure why it would have two connections tho unless it does vent back to the inlet :? it should be the last thing in the system.
What make is it?
