Right as some of you might know i'm going to OZ in 3 weeks. Bought a cheap Saxo VTS to run around in till i go. Now its developed a problem!!
Basically the tickover is all over the place, its down on power and when you change gear it revs about 1k higher
ie you change gear at 4k and it revs to 5k when you dip the clutch and surges froward when you release the clutch.
They have:
Stepper motor for idle.
MAP sensor
Throttle position sensor
Coolent temp sensor
I at first thought it could have been the stepper motor letting air in, but when my dad followed me it was black smoking slightly, this has led me to think that the coolent temp sensor is wanked giving the ecu false readings so it thinks its cold. Then when the revs rise the ecu reduces the fueling making the revs drop etc etc etc
I've ordered a new temp sensor.
Does anybody else have any views? How do MAP sensors work?
----------Sold 'R no 3! Gettin 'R no 4 when i get to OZ----------
They have:
MAP sensor
Coolent temp sensor
