mattygti-r
right my R has caused me no grief in the past 18months of ownership apart from one alternator and a battery goign (was a little jap spec one so expect it)
right taken the car out today and its had a good run down to southhampton and back the other day too....used it today as i say no prbs
not driven it hard (it never gets driven hard)
ive an AP paddle clutch which has a habbit of "rattling" when you release the clutch peddle sounds like realease bearing but its been like that since i picked it up (and the clutch was put in about 2weeks by RC before i got it)
went out to the car this evening, it started fine....went to select First ...nothing....went to second nothing...etc 3 4, 5, nothing tried again ...nothing
depressed clutch (pressed it a few times) then tried to select without clutch...finally after about 5-6 times it went into first, second and all the gears....
drove the car about 5-7miles back to mine...clutch /gear select is fine...
what could be wrong? the clutch has covered 30k miles if that...and the car does not get "launched"
gearbox dont like going into first when cold....
and the fluid has not been changed in it for some time (just checked last change) by previous owner)
any help appreciated as im shitting it could be the box
