OK.. I have problem with my daily work runner. 1990 Celica GT (Front WD).
I recently replaced all brake pads (3K miles ago). They squealed a bit at first and created a lot of dust cos the discs are far from perfect but then they seemed to have bedded in fine.
I have a problem now when with any left steering lock at all (e.g. changing lanes on the motorway). I get a metallic swishing / rubbing noise from the driver's side rear wheel.
It sounds very like the noise from a brake pad level warning clip rubbing the disc. In that it's pitch and sound increases with road speed - so I'm sure it's a rotating part rubbing something else.
However, the rear pads do not have warning clips on.
I have had the rear wheel off but can't see anything obvious. But as it only happens on left lock only I'm not surprised.
What I did notice though was that the bushes in the suspension tie arms that hold the wheel hub square are worn... there's 2 per rear wheel. So that if I grab the wheel - one hand to the front one back I can move it. I can see the play is in these bushes and if I try the play in a vertical plane, there's none - so I'm guessing the wheel bearings are OK.
However, I can't see why I get a speed related rotational noise on left turns only. It must be something to do with how the wheel moves on a left turn.
The other rear wheel has similar play in the bushes but makes no noises at all.
I'm being a cheapskate here... I don't want to shell out for new bushes as I am spending all my dosh on the R at the moment. I use the Celica to do 80 miles on the M25 / M1 each day and that's it.
Any other thoughts before I replace the suspension bushes??
I'm just confused that it is on left turn only....
hmmm
GeeTee 8)
hmmm
GeeTee 8)
