jjs
hi have a problem with charging circuit, changed alternator, voltage at battery, 12 volts, start car voltage approx the same, if you disconnect the wire from the alternator that connects to the battery and reconnect it you then get 14 volts, is there a relay or something in the circuit that is being rest by disconnecting then reconecting this wire ?
