hey guys.
my pulsar has started to produce no power. on cold start it runs fine through the whole revrange. if it comes to an operating temp of 70 deg oil or water it will reduce ignition on load to zero. it feels like it hold back and the consult says it runs sometimes lean.
car is standard apart from now a walbro incl direct feed from bat, turboknee back exh in 3 and 2,5" fmic.
the spurkplugs are white. gap is at 0.7. 8grade ngks new before 2k km.
ive changed the fuel filter before a month and had a short run on 10% e85 over a full tank of roz 100 once.at this time a jdm original ecu was fitted.
ive changed the stock fuel pump for a walbro with direct feed. ive changed the afm cause ive had a fault in the ecu. ive fitted a eudm ecu with a daughterboard with 4 mapsmand run the standard map.
car runs as said on warm up as it should run. has a lot of torque and power. sometimeswhennengine is warm it runs fine and had good power but most of the time it hold back and reduces ignition. on much forums it says it could be the det sensor, ive ordered one this weekmand will change that too. but i cant imagine why my carmismrunning that lean like it do.
could the run on e 85 (as i said only 8 litres overma full tank of roz 100 vpower) have caused damage to the fuel'filter, fpr, or a injector itself?
ive ordered now 560 evo injectors a z32 afm and a det sensor to run the chipped ecu. but i have no idea where to search for this problem.
ive used the search on here, the modifiers and both sr20forums.
has anyone an idea?
car is standard apart from exh. fmic, walbro with direct feed. it has now original 78k kms on the clock new sparkplugs, fuel filter etc. std boost.
thanks in advance for every answer.
im sorry for my bad english.
cheers
has anyone an idea?
cheers
