E
Eric Yellow
I'm having kind of a strange problem.
I've fitted a set of 550cc injectors and upped the boost a "bit"
So I'm runing at 1.6 bar at the moment on the standard turbo :? , Q45 MAF, 550cc injectors and an SAFC to control them, but when I accelerate (full throttle offcourse!) and pull through to about 6500rpm+ and shift to next gear and floor is again, it starts to splutter a bit and then goes on like nothing happened...
It's overfuelling at that time, could it be that there is getting to much fuel in just before the turbo is on full boost again?
Tried setting the SAFC lower at higher rpm's but then it's not getting enough fuel and it's holding back a bit when flooring it...don't want that to happen..
Tried altering timing, advance and retard, didn't have a good effect.
Fuel filter is new, plugs (iridium) new, full Goose, Walbro pump new, etc...
Injectors are 2nd hand and will be cleaned today.
Anybody got other suggestions where to look at?
