NO Boost?
frp
as title. the car has been fine,now it won't go past 0.00 on the avcr or my two other gauges. I've checked the actuator seems ok. the only other thing I have noticed is on adle its between o.oo and -20mmhg?
steve
Either a major boost leak or the turbo isn't spinning up at all. You would expect to see some positive pressure, no matter what ?!
Maybe the actuator diaphragm is shot and cant hold the wastegate shut ?!
Check you intercooler and all pipes and check for a leak between the manifold and turbo !
Is the car getting noisy? ie turbo/manifold bolts loose?
Can you feel the car boosting when you drive it?
kirko
i fixed it for him on sunday there was a signal hose split, it was the one that goes to the gauge through the bulkhead it took some finding!!
frp
yeah cheers fella. by the feel of things its been leaking for a while!
Should be even better when my new ic pipes are done instead of my soft 1000year old samco eh mr K.
