no boost
nissans rule
just wondering if anyone can help with my R .
The prob is it basically wont boost just fitted a new engine and it wont boost over.2 bar
looked at all hoses every thing seems ok.
please help cause it is wrecking my head.:cry:
geetee
chech the actuator on the back of the turbo.
It is quite common for the little clip to come off and the rod come off the wastegate - so any amount of boost just opens the wastegate and goes down the exhaust.
nissans rule
thanks ill check it out tommorrow..
oh and by the way what would u recomend to b the first mod i do a fmic or a ecu for our crap petrol .
geetee
Not sure what the question is....
what did I do to make it come off? Nothing - it just decided to disappear.
what did I do to fix it? got another clip and put it on. It can be done without taking the turbo off if you have rubber fingers. I ended up taking the turbo off to do it.
2nd time it happened I got angry and ground the pin off, drilled the arm and put a bolt through the lot with an arrangement of washers, locknuts and threadlock. It won't happen again :)
Graham
nissans rule
back again checked the wastegate all moving freely and intact.
oh have the actuater off and saw that u can adjust the rod couid it b that.
any advice ?
