does anyone use the Nissdata scan tool? if so, were there any problems with it? im having problems with mine just wanted to see if someone had similar problems.
when i start the car it works fine...but as soon as i put it in to 1st and release the clutch to get moving, the display says "Framerror" in the top left corner and all the readings freeze. after that i unplug it while the car is running and reconnect it and it works fine from then on. if i dont find out how to fix it, im just going to wire in a switch to disable power to the unit to reset it when it freezes and prevent me from disconnecting it and reconnecting i everytime i set off.
