Are these an ok plug to use? I think the 11 just means they are pre-gapped at .044, is that an okay gap? I can get these discounted at work so i hope they will work.
Afaik, the plug you mention isn't the correct one for the GTiR, although it's not far off. I think the actual plus are BKR7EIX ?!
The stock gap should be 0.7 - 0.8 mm, not sure what that is in imperial sizes. Not that it matters too much though as, if you get the right plug, it will be pre-gapped for the specific application.
It seems that 0.8 mm is about .032 thousandths of an inch so a .044 gap is much too big. Since they are the same exact plug just with a different gap, i wonder if i could close them up a bit.
11 means 1.1mm, so yes too big-close them up.
What boost are you running? 7s may be too hot, you may need 8s if running 1bar, possibly colder if running a big spec.
