First of all, greetings from Norway ive heard this page was the best, so here it goes:
i got myself a new turbo for my sunny gti-r, it has smaller exhaust house for faster spoolup and compressor wheel from a gt28rs turbo and 360 "chamber?" instead of 280.. and original wastegate (good for 1.3bar)
first run was on a greddy bspec II electronic boost controller. I tested many options but dident get it to run clean without peaking so i gave it up.. then i tested a manual simple boost controller, just with a simple turn-wheel.. And it still peak! Even on the lowest default setting it peaks up to aprox 1.1 bar at 2nd gear, and 0.9-1.1 and 3rd.. Why? the boost controller is the same one that another guy from my place has on hes gti-r, and he runs at 1.7bar
is the original wastegate to small? the hoses should be fine, its gasoline hoses, never had any problems with em expanding before.
my setup is: walbro fuel pump,moongoose exhaust,custom turbo as mentioned above and open KN filter.
A/F ratio is fine too
so, smaller turbo = no go, at gti-r?
sry if ive made some wrong expressions but all the .no places are clueless.
