GTI-R Kid
Hey guy
Just after getting some new gauges for the GTI-R but not sure how to connect them all up. I understand the instructions and all that, my problem lies with how to plumb in the new sensors? Do the original sensors serve any purpose other than a feed for the center gauges, and would it do any harm to remove them (oil temp and pressure) and replace them with the sensors for our new gauges? Do they send any signal to the ecu that would mean I can't replace them?
We'll be ditching the three factory center gauges and fitting oil temp & pressure, along with water temp and boost. Anyone suggest where is best to tee for the boost reading? Anyone know where's cheapest to get an adaptor for the water temp (or anyone know the diameter of the factory hose so I can do some searching)?
Finally, I've come across some pics of brass adapters that allow the fitment of the factory sensor and aftermarket sensor to the same point on the block. Its like an extended bolt head where the factory sensor attaches at the end, and an aftermarket sensor can connect half way up its length - anyone know where these can be sourced?
Cheers in advance for any replies.8)
