New Brain
LeeSmith
If I were to stick a remapped Dakar ECU in my car what what would I benifit from, I have a standard ECU at the moment...
Thanks in advance
gtiroz
Administrator
[lack of replies can usually be attributed to question content]
RA or RB wouldnt matter - any ecu that has been remapped has been done so for the setup of the car at the time - so you could get lucky and it may be slightly better, but it may be heaps worse - all depends on what mods it was set up for...
(ie. if the car it came off had bigger injectors and a z32 afm and you have the stock items it will most likely not run very well)
as for stock RA vs stock RB - the only difference is in the fuel/timing maps (the rally ones are more aggressive)
LeeSmith
thank you, i'll check what the chip was setup for before i buy it then...I'll put another post up when I know more. Thanks for your help :wink:
