By the way what is a FMIC?
front mounted intercooler
id stick to 1 bar on standard fueling, especially if you're on a tight budget- if anything goes pop then your kinda stuck :?
the only thing ive heard about bleed valve type things is that they cant compensate for varying ambient temperatures, so you set it on a hot day for 1 bar and then when the temperatures drop it may be running 1.1bar for instance. - either buy a good boost gauge or save up and get:
boost controller : apexi avcr
fueling : apexi safcII + walbro pump
exhaust- most go mongoose :roll: but any free flowing turbo back system minus the cat is good.
induction kit- apexi, or i run the big k&n that forge supply.
possibly a new dump valve, im not sure what pressure the standard one can cope with.
the standard top mount will be ok, you could front mount it, but if on a tight budget, id spend it on a good re-map and see what the tuner can safely get from the car.
the standard clutch may last, it may not, but only replace it whan it starts to slip- just run it into the ground.
but if you want my opinion, if youve just bought the car get used to it before modding it.
give it a good service- engine, gearbox, transfer box and rear diff oils, oil and fuel filters, leads dizzy cap, rotor arm, new plugs, flush radiator, new brake and clutch fluids, flush out the intercooler with petrol or carb cleaner.
if you are on a tight budget id spend the money on looking after the car and making sure its at 100%. if you let them deteriorate they will cost an absolute fortune to put right.
