Need to know some engine specs
CanadianR
Does anybody know where to find the following for a stock GTiR motor:
Cylinder Bore (mm)
Crank Stroke (mm)
Cylinder Head
Intake (cc's)
Intake Valve Diameter (mm)
Exhaust Valve Diameter (mm)
Camshafts
Rocker Design (Stamped/Roller Tip/Roller)
Intake Duration
Intake Lift @ valve
Exhaust Duration
Exhaust Lift @ valve
Advance/Return
Lobe Seperation
Induction
CFM rating
Turbo
HP Rating
CFM Rating
Efficiency at stock boost
That's about it that I can remember I need.
I'm looking at a program for a computer and need the values.
Thanks.:thumbsup:
Jesse,
Bore and stroke are both 86mm, bringing the CC out at 1998. And the cams are just a conventional design, with no roller tips etc... That's all I can help you with though bud.
Paul
