I need help installing my Apexi Turbo timer!
I do no have the harness for it
I do have the instructions, but they do not tell which wire to tap at the ignition.
One wire goes to the handbrake switch, a wire taps the A/F signal wire at the ECU and one taps the ground at the ECU, so far everything is ok.
But since I don't have a GTI-R specific harness, I need to hard wire 3 wires from the timer to wires from my ignition.
I have these three wires that I'm not sure where to tap:
Red: 12 V+ Constant
Blue: IG2 Output
Green: IG1 Output
There is 5 wires going to my ignition:
Black with a red stripe
White with a blue stripe
White (bigger than other wires)
Black with a white stripe (bigger than other wires)
Black with a yellow stripe
Now, the first three listed have been tapped before, probably my R had a timer at one point. And I'm pretty sure that the black with red stripe is the 12V.
So basically I need to know which wire is the IG1 Output and which is the IG2 Output.
Anyone can help me or know where I could find out which wire does what going to the ignition?
thanks
mat
Red: 12 V+ Constant
Blue: IG2 Output
Green: IG1 Output
thanks
mat
