NEED HELP BEFORE I BURN MY R
N
NISM0
CANT POST IN THE RELIAVANT PLACE BUT IFI DON'T FIND THE ANSWER TO MY R\S PROBLEM I'M GOIN TO BURN IT
IT DRIVES NICE WHEN DRIVING NORMALY BUT AS SOON AS I WANT TO OVER TAKE IT POPS BANGS AND WILL NOT GO, ALSO IDLES ERATICALY AND WHEN HOT HARD TO STAR, HAS JUST HAD IN LAST FEW MONTHS ANOTHER ENGINE PLEASE HELP THIS IS MY SECOND R
EMAIL DO2ER@HOTMAIL.COM
JIMMYBACK
last service? and wot did you have done?
sounds like it detting so the limiter is kicking in :shock:
N
NISM0
POP BANG NO GO
JUST BEEN SERVICED, I ONLY PURCHASED THIS LAST WEEK AND WAS FINE WHEN I COLLECTED IT.
N
NISM0
FORGOT
THE OIL HAS BEEN DEF DONE +BRAKES UM HKS FILTER LOOKS A BIT MANKY I FILLED UP WITH 97 RON PETRAL
R-Type
Do a fault code check.
Use the search function on the forum to find how it's done.
Sounds like one or more of your sensors malfunctioning.
JIMMYBACK
he cant hes not a member :shock: :?
stomski
mine did exactly the same when i first got it. my mechanic 'ZIA' came over and it was diagnosed as having a split boost hose, sorted in 2mins.
best of luck :wink:
Rishi
Still waiting on some shims!
So when you floor it, its starts spluttering...
And its hard to start...
Sounds like you need to change your Plugs, Leads, Rotor arm etc...
Also give the MAF a good clean...
Sometimes the simple answer can be the right one...
Rishi
GTiR Jon
Sounds like one of the boost pipes has a split! When the engine gets hot it heats the silscone so that its softer making the split open causing more probs!
Had that prob before myself!
If it has a top mount and the plugs have been replaced check the boost hose that runs under it has been reconnected.
pyrotecnic
I had the same proplem and ended up being a ht lead tracking. Changed it and all fixed. It was a arse to find though.
