Need advice please!
  • Thread starter heaven is a gtir (bry)
  • Start date
H
I am doing my piston rings :cry: in the new year and i need some advice on a few things please.
1. do i need to take the engine out or can i just get away with taking the head, sump and inlet manifold off?
2. how can i tell if they are standard pistons. Will they have any kind of marking on the top like a stamp. Who knows what the japs might have done. :D
3. is it a normal set up on the pistons e.g 3 rings. 2 compression and 1 oil or is there only 2 rings.
4. has anyone got and prices on things like top end gaskets, bottom end gaskets and piston rings for standard pistons. Someone must have bought these parts from a nissan dealer before now.
All help very much appreciated. 8) Bry.
skiddusmarkus
The pistons say "54C" on them.A full engine gasket kit is about £150 and a head kit is about £100.Both are usually in stock but order early to save waiting.
H
Is 54c A standard piston ring? Engine out or in? Is it 2 or 3 rings?
skiddusmarkus
Most people would take the engine out if replacing the rings in case you need a rebore.
The 54C is stamped ontot he pistons themselves.
I think there are 3 sets of rings.
H
OK thanks for the help. :D
Anyone else welcome to post their views.
GAZ P
If your going to the trouble of replacing the rings why not fit a set of forged pistons at the same time :D .Might save the pain of having to rebuild the engine a second time if you up the boost :oops: .Should be able to get a set for under £500 :shock:
H
Good :!: i will have to see how much money i spend on beer over xmas :D :D :D :D
:?: Where would be the best place to get them from. I have looked at norris design and they are £700 if memory serves me correct. :cry:
