Mystery plug - Do you know what it is???
Pretty obvious from the title, I’ve got the engine back in the car, however I am struggling to work out what the last and only plug in the engine bay does/goes/connects to?
As you can see below its been connected to something, but in the engine bay there is NOTHING available to plug it into, nor is there anything that gives any clues where it should go to either?
I (think) know it’s a power connector as I’ve traced it to the coil pack, but the mystery plug has nothing to connect to and as there is no power going to the coil pack, so the car won’t start! :(
So the question is: does anyone recognise the plug, where it should go to and have and pictures of where it should be connected to as I am 100% stumped.
I’m guessing that I might be missing another connector, but when I look in the engine bay everything is connected up, so I’m pretty confused.
Below are a load of photos of the mystery plug, the engine bay and surrounding area.
Any photos or help would be appreciated!
Engine Bay
The plug
And (I think) it connects to the coil pack
Random engine bays shots
(and yes I know those brown and purple connectors are there and they they don't connect to the "mystery plug")
That's the plug for the optional gigawatt generator you need to run 1 bar ;-)
Or on the other hand it's what Ed said.
That's almost spot on, if possible could you take a photo of the wires going into the other side of the connector?
Need to forward that on to someone so that they also understand what I'm relaying!
As I say to the missus "as good as its gona get" as not alot of room to take pic! The grey connector goes to the back of the dizzy..!! Hope it helps mate!!
