my car is doing this :(
D
D4VE-GTI-R
my car has just started doing this noise. it does it on start up for a second or 2 then it stops. then when i drive it, it starts around 2000rpm then stops when the turbo kicks in
http://nz.youtube.com/watch?v=rHkwWT_jQQk&feature=related
i hate my car lol only had i 4 weeks and it f***ed
there is this comment on the vide:
its not either of those its a timing chain guide its very common take the front cover off and you'll see where the guides are and you'll find a broken one...I'll bet its on the driver side
is this true? the noise is comming from the drivers side lol
unfortunately for you that most definately sounds like a bigend knock!
and it also fits in with your description of when its happening ie at start up and around 2-3k rpm when feathering the throttle.
it dissapears when on boost as the rods are then under full load.
now heres the bad bit, you will probably 99% need to now remove the crank and get this fully sorted.
if you persist on driving it you will render the crank unservicable as you WILL spin a shell then you have major problems.
D
D4VE-GTI-R
:( what sort of price am i looking at to get it repaired at a garage?
give me a bell when im back off holiday dave and we'll see if we can sort something out for you!
my numbers on contact us page on website below
im leaving later today and back on the 6th october
