I just found this on there site :shock: :shock: it's the spec of my M48 pro.
General
Microprocessor 32 Bit 33 MHz with Time CO Processor
Quality Standard ISO 9001
Manufacturing Standard IPC-S-815-A Class 3 High Reliability
Warranty 1 year Parts & Labour
Burn In -50 to 70°C for 32 Hrs
ECU Control Software stored in updatable FLASH memory
High RFI Immunity
Low heat generation
Battery transient protection
Environmentally sealed electronics
Water proof connector with gold plated contacts
Case Size 150 x 100 x 36 mm (5.9 x 3.9 x 1.4 inches)
Weight 0.48 kg (17 oz)
Cylinders 1,2,3,4,5,6,7,8,12
Engines 2 stroke, 4 stroke, Rotary (1~4), Odd or Even fire
Maximum RPM >15,000 RPM
Fuel Calibration
Accuracy 0.00001 seconds
All RPM & Load sites are user programmable
Main Table (3D) 40 RPM sites x 21 Load sites (840 points)
End of Injection (3D) 20 RPM sites x 6 Load sites
Overall Trim ±99 %
Individual Cylinder Trim ±99 %
Hi / Lo Injector Balance (3D) 20 RPM sites x 11 Load sites
Hi / Lo End of Injection (3D) 20 RPM sites x 11 Load sites
Eng Temp & Air Temp comps
MAP modifier compensation
Two Auxiliary compensation
Injector Dead Time Compensation
Accel Clamp, Decay & Sensitivity
Deccel Clamp, Decay & Sensitivity
Cold Start
Injection
8 group sequential
User programmable injector current
0.5~6 Amps peak
Battery Comp to suit any injector
Boost Control Calibration
Main Table (3D) 20 RPM sites x 10 Throttle sites or 10 Gear sites
Overall Trim
Engine Temp & Air Temp comps
One Auxiliary compensation
Ignition Outputs
Up to 4 Ignition Outputs
One output may drive up to 8 coils using the MoTeC Ignition Expander
Versatile Ignition Interface allows connection to most OEM ignition systems including :
GM EST DFI systems
FORD EDIS DFI systems
Many Others
Ignition Calibration
Accuracy 0.25 degrees
Overall Trim ±99 %
Rotary Split 20 RPM x 11 Load
MAP compensation
Two Auxiliary compensations
Dwell Time 20 RPM x11 Battery
Odd fire engine capability Each Top Dead Centre angle may be specified Resolution 0.5 degree
Trigger Sensors
Directly compatible with most OEM trigger systems including :
HALL, Magnetic and Optical types
Multi Tooth (eg Mazda and Toyota)
1 or 2 Missing Teeth (eg Porsche)
Many other special types, eg. Ford Narrow Tooth, Nissan Optical, Harley Davidson
Air Fuel Ratio Sensor
High accuracy Wide Band Air Fuel Ratio Sensor Input (Optional)
Range 0.75 to 1.20 Lambda
Resolution 0.01 Lambda
Other Sensors
Throttle Pos, Manifold Pressure, Engine Temp & Air Temp
2 Auxiliary Sensor inputs
2 Digital / Speed Inputs
Data Logging
Optional Logging memory allows logging of all ECU parameters
Memory Size 512 KByte
Logging Rate 1~20 sets / sec
Logging Time 38 minutes at 5 sets / sec (28 Parameters+Diags)
PC Software is available for analysis of the logged data
Special Functions
Traction Control & Launch Control (2 wheel speed sensors) (or 4 sensors using the MoTeC TC Mux)
Gear Change Ignition Cut
Wide Band or Narrow Band Air Fuel Ratio Control (3D mapped)
Over Run Boost Enhancement
Warning Alarms (Sensor HI / LO)
Gear Detection
Ground Speed Limiting
Dual RPM Limit
Nitrous Oxide Enrich / Retard
Air Conditioner Request
Over Run Fuel Cut
Sensor Calibration Tables
RPM Limit Hard or Soft Cut Fuel and / or Ignition Cut
Auxiliary Outputs
Four general purpose outputs (2 shared with ignition outputs) The outputs may be used for :
Turbo Wastegate Control
Idle Speed Control
Fuel Used Pulse
Tacho Output
Shift Light (Gear Dependent)
Driver Warning Alarm
RPM / Load dependant device
User Defined Table (20x11) with definable axis parameters
Slip Warning
Fuel Pump Relay
Thermatic Fan
Air Conditioner Fan or Clutch
Diagnostics
Injectors Open Circuit, Short Circuit, Peak Current Not Reached
Sensors Open & Short circuit
Operating Errors RPM Limit Exceeded, Injector Overduty, Over Boost, Low Battery, REF Error etc.
Operating Conditions
Internal Temp Range -10~85°C
Ambient Temp -10~70°C (Depending on load & ventilation)
Operating Voltage 6~22V DC
Operating Current 0.4 A max
Reverse Battery External Fuse
Calibration
Personal Computer (see PC Requirements)
Telemetry Link
Optional Telemetry Link allows real time monitoring and data logging
READ AND WEEP :lol: .
rob
General
High RFI Immunity
Low heat generation
Fuel Calibration
Overall Trim ±99 %
Cold Start
Injection
8 group sequential
0.5~6 Amps peak
Overall Trim
Ignition Outputs
GM EST DFI systems
Many Others
Overall Trim ±99 %
MAP compensation
Trigger Sensors
Other Sensors
Data Logging
Special Functions
Gear Detection
Dual RPM Limit
Over Run Fuel Cut
Auxiliary Outputs
Idle Speed Control
Fuel Used Pulse
Tacho Output
Slip Warning
Fuel Pump Relay
Thermatic Fan
Diagnostics
Calibration
Telemetry Link
rob
