most power
hks-r
Which single plate clutch kit can handle the most power?
Instead of the twin disc route
Act 565lbs
Unsprung or spring?
I need to order it asap so cheers for help
rich1216
I run that clutch rigid plate no springs extreme duty cover plate. Very light for what it is and doesn't act like a paddle
Check my understanding, are you looking for a single plate to handle 565 lb/ft of torque from the engine? I'm out of ideas if you are but up to 450lb/ft you can probably get away with single plate. At 430 mine was fine
I ran RPS with sprung plates, not the best but worked. Helix are another option I think. I'd previously run a superclutch twin plate setup on both metal and organic plates. Great clutch but pants when commuting as it kept destroying plates. I went single plate as a compromise.
