missing under boost
jeff
being a gti-r newbie, looking for some help here
intermittant misfire as soon as boost comes in, power drops considerably when you nail it, new plugs - leads, distributor cap and cleaned up rotor arm.
uprated airfilter and exhaust fitted, at some point i think its had a boost controller as the soleniod is loopped and the vacum hose off the air intake just afetr air fllow meter has been blanked. may be relevant . may not be??
also wallbro 225 feul pump fitted in anticipation of some other mods
any thing else i should do?
thanks
Matty B
Has it just started doing it ? Could be the air flow meter playing up. If you've got a mate with an 'R' try there AFM on your motor, thats what i did anyway when mine fooked up.
jeff
they are 2nd hand magnecors - ive sorted out the vacum hosing as the boost solenoid had been looped and its running better, but, still intermittant misssing - altho its not nearly as bad??
dont know anyone else with an R nearby.
are they symptoms the same when the afm fucked up mate, its defo only missing under boost.
gtir_pimp
where abouts are you then? gaping the plugs shouldnt make any difference. put my new ones straight in and its fine. do you know anyone with a KV tester to test the leads?
jeff
i can see how the plugs having too big a gap could make it miss, as the boost increases the pressure inside the cylinder making it harder for the spark to jump, but i trust my mechanic to have gapped them correctly - he posts on here haha. wot should the gap be on them? and should it be closed when running increased boost?
suppose it could be poss ive got the wrong plugs - might pull one out to check
saddler
my can got hesitation (missfire) under boost @1bar... try them at 0.8
saddler
do a search of the above.. and then tell me gaping the plugs shouldnt make any difference
gtir_pimp
just saying i went to allparts, got new plugs put them in and away i went with no problems at 1bar or 1.3bar. it will obviously make a difference if the gaps to close or too far but if theyre new and not been messed with they should be ok. or are they a colder plug or something?
Does it depend which plug you're using? Maybe it makes a big difference with iridium plugs, but not the normal kind?
Matty B
When did it start doing it ? Did you change some parts and it started doing it or was it running fine and then it started ?
catchmeifyoucan01
could be your fuel pump i had the same issue with my walbro fuel pump and that was only a week old! and that was causing it to miss -fire when hitting boost.
jeff
cheers for all the suggestions people
ill check them out over the next week, as im away until the weekend
