minimum
You must mean idle rpm ?!
The ecu will regulate this so, there's no need for you to.
You can adjust it though by disconnecting the TPS (throttle position sensor) and turning the idle screw on the side of the plenum.
Iirc, the manual says it should be between 850 and 950 rpm ?!
dont know what you mean?
pictures of what exactly, engine? car? inlet manifold????
antgtir
Mine sits at 900 to 950 on idle.
If you have a high idle it may be due to something else mate, i would look into this before you try adjusting the idle manually, you may just end up masking a different problem.
Ant.
