Measuring caster
Sunny-D
Is it possible to accuratley measure caster with a camber gauge?
Ive seen a few things on the web, some were measured using a camber gauge zero'd when the wheel is 15d from parallel and then re-measured at 15d opposite lock, does this give the caster measurment?
stumo
I've done caster that way with an angle guage, it's the difference between the two angles.
watoga
Does this require turntables for the wheels? Or can it be done using a protractor and some chalk? I have a camber gauge, but no turntables.....................
Cheers,
Dave
