May be selling or breaking my car.
Right due to getting fed up with being messed around with pushing this car any further i may be selling or breaking my car here is the spec list and prices of the parts as new:-
a seperate thred wil be done with parts prices wanted, the car will not be stripped till it is all sold.
syvecs s6gp with full knock control,
Will come with 3 and 4 bar map sensor, iat sensor ,boost solinoid and the distributor to allow you to not need a seperate crank trigger
£2500
Owen developments turbo which is basically a fully specced bronze bearing caged, stainless heat shield modified billet wheel turbo capable of 600+bhp and to run 3 bar boost
£1700
fully built engine with cams,head work basically everything to run 600 and beyond
£4500
gearbox this has ppg final drive, par straight cut 1-4th ,quaiffe 5th, billet steel selector fork's, nismo 1.5 way centre diff,cryo'd casings and billet case brace
£14,000
nismo front diff 1.5 way
£550
Nismo rear 1.5 way
£550
multi plate super clutch with fly wheel etc
£1500
fuel system inc bosch pumps,swirl pot's, sard fpr, and a relays + bracpan sealed box and aeroquip lines and fittings
£1000
corbaeu kevlar seats
£1000
harnesses
£400
enkei rps 01 nismo 8 x 16 wheels and 215,40/16 toyo t1r tyres
£1000
brembo calipers and front discs on ali bells 308mm
£500
hi spec big rear disc and caliper brackets
£300
shell with nylon bushes from front to back
£1000
cage with harness and door bars in white by safety devices
£600
stainless 3" exhaust with 3 silencers and v band fittings
£400
bc adjustables
£500
hks intercooler
£200
kevlar mint bonnet
£500
carbon door cards
£400
oil cooler kit
£200
and there is so much more.... like nismo 1.5 way centre diff, spare gearbox parts, spare block,crank pistons,tomei rods.......the list is huge.
So how much interest is there.
Or does someone want the whole car with spares for £25,000
pulsarmoley
Cant believe im reading this, was looking forward to seeing how much further you could push this car...
I would be interested in the carbon doorcards if you do go ahead and break it.
STU666V
You get out of the wrong side of the bed this morning?
Go and have a fag and have a re-think! :) GLWTS
bensmith907
Where are you going to go from a GTi-R then danny? Or are you going to focus your attention towards Anikia?
500bhp and 435lb ft torque at 1.6-1.7bar on shell optimax, and approx 10.5 sec 1/4 mile. top speed about 185mph. it beats superbike's den.
With new ignition and race fuel with the boost upped it should crack 600 which will be done in the next week.
have all dyno fig's in a folder it made 464 at 1.5 bar. the billet turbo will only really wake up at 30psi/2bar and above.
Mad
Don't do it Dan, you will only regret it. There is far too much time, effort and money spent on it.
