may be for sale soon
Status
Not open for further replies.
npulsar
im the only uk owner since imported had the car 5 plus year's
l reg red used every day for work seviced evry 2000 mile's
most of modified part's are new i only cover around 4000miles a year
under sealed 4 wheel alligned good tyres all round
car has sailed threw every mot for last 5 years ie everthing is new under the car.
run's sweet no smoke nock or bang's will also come with some spare's
rear diff lightened flywheel od's and sod's. 79000 on the clock runing around 330bhp
and reliable looking for only £4000
only seling as baby now here.
solid std engine
silicon hose's all round
gtir spark plug cover
irdium plugs
8mm leads
mocal 19 row top mount oil cooler
50mm race alloy rad new.
hks air filter
z32 afm
sard 700cc injectors
hks filter
blitz fmic very rare
greedy profec boost control 1.2 bar
dp tubulor manifold boxed for strength with hks gasket's
full mongoose s/s system de cat 5inch with moded down pipe. now with new fron exit.
12mm bonnet spacers help keep temps down
garet gt 3071 r turbo with ajustible actuater
nismo srutbraces front and rear
tein super street's suspension
white line ars's
poly bushes all round.
walbro 255 f pump
17"lightweight wheel's
clear indicators
quick shift gear stick
308mm nissan 4 pot fronts
300mm rears two piece disc's all round
with refurbed calipers all round as new see pics
braided lines all round
red stuff pad's all round
white dial's chip'd for mph
air con remove'd
roof smoothe'd
never had abs from factory very good for track.
sunroof/aerial/rear wiper and motor remove'd
fia full weld in omp cage
fia omp seats
harness s belts with quick release bukle
white dials de resricted to mph
clifford cat 1 with ceterficate
nissan sump guard
fully sriped out
sparco mud flaps
sparco pedals
nardi s wheel
apexi turbo timer
apexi dump valve
greedy boost gauge
std ecu with remaped eproms 4 map box set at 1.2 bar only run on v power
got a 12.6 at pod 2008 at a very windy jap show
rally roof scoop with inner pods .
battery in boot
Never thought i would see the day. If you got paid a wage for the amount of time you spent on this car you would be loaded. :sad:
Status
