Maxima MAF and AFC setup
andym
Hi All,
I've tried searching but can't find what I'm looking for. I'm just wondering if anyone has used a MAF from a 3L Maxima and Apexi AFC?? And if they have could they give me some advice?? I would like to know whats the best settings to use on the AFC so I wouldn't be killing the engine??
Thanks in advance.
Andy.
C
Crazy
You will need to set the 'Sens' parameter. This setting is what determines the MAFS signal type in and out of the unit. You can change this if you are running a different type of MAFS. If you have a std MAFS, then the setting for 'Sens' will be In=5, Out=5. If you are running a Z32 MAFS it's In=2, Out=5 and if, like me, you have gone the whole hog and have a Q45 jammed in under the bonnet, it's In=1, Out=5
The rest of the setup is pretty straightforward on the S-AFC II.
