max boost on stock t28 turbo
weblizzer
hello everyone!
what is the max boost can handle on stock t28 turbo of gtir?.... i'm currently running on .9 bar ideally.. but i want to know if what is the safe max boost for it?..
let say if i want to change to 560cc injectors.. can i raise up the boost on it?
Thanks
Your best bet is to put a wide-band lambda sensor in the exhaust and see how much you can turn it up before the mixture is compromised. - I don't think it's got a lot of overhead in it, so if you want more boost with bigger injectors you probably want a bigger turbo too.
Fire & skill
Vintage member
Ive ran 1.3 with a daughterboard, was RR checked, fuelling was ok, inj duty at 97% and 332bhp - id say that's as much as you'll get!
bear in mind you'll prob need an uprated clutch to run that much boost not to mention an uprated fuel pump. I was using an electronic boost controller, no spikes with it. When youre running higher boost there is also a chance of leaks - check all your intercooler hoses are on tight and if possible get the clips changed to mikolor
