Master Cylinder...help.
Mr GTiR
As some of you may know my engine is out of the car.
Is it worth replacing or having the master cylinder seals replaced while the engine is out?
On the cover of the master cylinder there has been some signs of paint bubbling due to some fluid being on it. I think some fluid may have been split onto the cover as there have been no signs of any leaks before.
Are the seals expensive and is there anything else worth replacing?
Looking on FAST the other day, there isn't a seal kit listed, just a piston kit, which includes most if not all of the internals, so it may be worth just replacing the whole thing if there's not alot in the prices.
simzy
There is no point in messing around, just get a new one and then you will know that it is done.
It is a pain to change it once the Engine is back in
