nismo-400R said:
wonder why he said that then,i only want 1.2bar for the moment until i get some injectors and the z32
Because it will only just do and i think Ian is building in a bit of safety and reliability.
By all means go with the safc but,you car will not be as smooth or produce as much power as it would with a stand alone ecu.The safc has far fewer mapping points within the rev range compared to most of the stand alone ecu's and it really makes a difference to the smoothness and power/torque production.
If you go with the safc,you are only delaying the inevitable purchase of a decent ecu and then you'll be stuck with an outmodded/outdated safc that will eventually end up on flea bay for pennies.
You pays your money and takes your choice but i'd go with the ecu as it'll save you money in the end.
Then again,WTF do i know :yawn:
